kharrisma
- Joined
- Apr 24, 2018
- Messages
- 6
- Reaction score
- 0
Hi Forum Folke,
Like lots of others, I have a toilet that sweats practically all year 'round, even in Winter. I'd like to add an anti-sweat valve to the fill plumbing, but I frankly don't see how it could possibly work as a "drop-in," without some creative plumbing.
The toilet is easily 20 feet from the water heater (that's not counting the vertical rise). At the time of flush, the hot water pipe going to the valve is going to be full of cold water (having cooled in the basement over time). This is a 1.6 gallon flush toilet... I don't see the hot water ever even reaching the toilet by the time the fill valve closes, and even if it did, there wouldn't be much of it. You know how long you have to let the water run before you actually get HOT water from the tap!
Is there any way around this? I have this half-developed idea bouncing around involving a constantly recirculating loop, using a small pump at the water heater to circulate hot water through this loop, which the anti-sweat valve would be connected to by a very short stub. If I'm thinking clearly here, just the water from stub, through the hot port, and to the mix port of the valve would be cold (probably not even a cupful); just a second of flow and the hot water would be right there on demand, no waiting. I'm having some trouble visualizing how this would have to be plumbed into the existing plumbing, though. I'm picturing a pump teed off of the hot water output, piped to the location of the valve, two 90 ells (where the tee and stub actually feeding the valve would tap off from), and back to the water heater... but where would the return water go? The cold water feed to the heater? Would I need a check-valve in the "return from anti-sweat-valve" run to prevent cold water from flowing "wrong way" into the loop?
I think the concept is good, but I'm not familiar enough with the available hardware (or what it's properly called so I can ask for one) to figure this out on my own. Once the hard part of designing the circuit is done, the actual mechanics of installing the stuff should be a cinch... God knows I've done enough cutting/cleaning/sweating of tubing over the years, so far (knock wood) without leaks.
And even if it could be made to work, I'm not sure it's even economically feasible to do so... the pump would have to be always running (or have some sort of thermal sensor to know when to turn on and off, or be on a timer or something), and maybe the cost of running this thing, the extra time the heating elements in the heater would have to run, pulling more current from the electrical system, bigger monthly electric bill... I just dunno. Advice from far wiser heads than mine seems to be needed here. Appreciate your taking the time to read (and attempt to make sense of) this, and any ideas you may have.
