American Standard Pivot Rod
pasadena_commut
Sep 10, 2016
472
104
The pop up in one of our American Standard two handle bathroom sinks stopped popping up. On investigation, the pivot rod had corroded and snapped off right next to the pop up. The outside part of the rod is still shiny. Carefully examined the same part in the other sink's drain, with the same faucet, and that rod was still shiny everywhere.
I need to dig out the paperwork to see if there is a lifetime warranty on that sink, and so that part. Assuming no, the part looks like this (but maybe not "extra long"):
https://qualityplumbingsupply.com/american-standard-025088-0070a-pivot-rods-extra-long/
Are all AS pivot rods the same geometry (other than length of the bar on the outside of the drain) or do they have different ball and rod diameters/lengths? Home Depot doesn't seem to carry this part, only the whole drain, or a Danco part. Should I consider replacing the whole drain rather than the part, on the theory that whatever ate through that rod probably has done a number on the drain too? (No idea why it corroded that badly, we don't pour anything acidic into these sinks. Maybe one of my kids has acid saliva like in Alien.)
Apparently I didn't save the paperwork in the usual place, so poked around in the garage and found a box that one of the faucets had come in. 2904222.002 "Williamsburg". No letter after the numbers. No notes in the box, but it had an unused drain assembly in it, the pipe parts of which are all metal, which looks a lot like this:
https://www.homedepot.com/p/America...go-in-Polished-Chrome-M953450-0020A/203670989
I don't see "American Standard" on the drain assembly anywhere, just an "N" on the big metal piece where the pivot rod plugs in. Is that how American Standard marks that part? There is also a possibility that it is from a Moen bathroom faucet and was just placed into the wrong box.
Examined the pop ups on the unused assembly and the existing two in the sinks, and they were all different.
Odd.
Since I have an unused and apparently functional drain assembly, I guess I might as well use it.
Edit: Or not? It has been in that box for 24 years.
Why don't you try to just use the new pivot rod in the old assembly? Takes 2 minutes to test, and if (I suspect "when") it works you would have saved an hour or more of work swapping out the whole drain assembly.
