Hi all, I've got a shallow well and suddenly there is a lot of air intermittently coming out of the faucets and the pump takes at least 10 minutes to hit the cut off, once it cuts on where it used to take just a few. Sometimes there is a lot of air and other times there is just a little bit of intermittent air from faucets. It will get to 3/4 pressure then struggle to get the last 10lbs to get to cut off according to the pressure gauge. I can hear air bubbling in the pressure tank every time a faucet is used or toilet is flushed which hadn't been the case prior. I emptied and tested the pressure tank with a tire gauge and it has the proper 28lb charge for a 30lb cut on and no water comes out of the tank at the pressure test chuck. The tank is 10 years old. This is a seasonal cabin and gets only light weekend summer use three months of the year. The pump is not short cycling at all. Closing the system with the valve after the pressure tank which is before the whole house filter makes no difference. This leads me to believe it is one of three things causing the problem.
-The pump has worn out though it sounds the same as before this started (I estimate it to be 15 years old)
-The check valve has gone bad, I estimate it to be decades old. (do brass valves really go out?)
-the well is drying out though no neighbors are complaining of a dry well.
Does this sound logical? I'm making these assumptions based on what i've read but am looking for any suggestions or things I might me overlooking. The cabin is far away and I need to collect any replacement parts and bring them with.
Thank you.
Thank you.
