1woody
I moved in this house 9 months ago and there has always been air in the hot water only, no air on the cold water side. When I first turn the hot water faucet on, there is water, but when the cold water starts to warm up, there is A bunch of air, then A mixture of air and water, by the time the water gets hot, the air clears up and there is only hot water. When I let the water sit for A hour or two and turn on the hot water, the same the same thing happens, it gets worse when the water is left off overnight. Somehow air keeps entering the system. This happens in the bathtub, bathroom sink, and the kitchen sink along with the clothes washing machine hook up. The well is A shallow well with the case about 18 inches underground with A rubber gasket between the cap and liner. Copper piping throughout the house. 3 days ago, I wasted money on A brand new tabletop electric hot water heater. (I went with the same set up as the old electric tabletop water heater was). Before going to bed I looked at the pressure gauge in the crawlspace and when I woke up the next morning, the pressure was the same as it was the night before. I replaced the old pressure gauge with A new one to make sure the gauge was working. Since there is no pressure drop at the gauge, that should eliminate the possibility of A leaky foot valve at the bottom of the well pump. I crawled under the house with flashlight, following all water pipes, and I didn't see any water leaks. It is so annoying to have the air and water splash on my shirt when I wash my hands, so any help would be greatly apricated. By the way the water doesn't splash on my shirt after the air works its way out. What is causing air to repeatedly enter the hot water?
