Hi,
I have a Toto legato toilet (with a unifit adapter) installed 4 years ago; I recently started noticing water seeping out of the base, through a small break in the caulk.
Would anyone have suggestions on how to diagnose the exact source of the break, without lifting the toilet? I'm hoping to figuring out whether it's a break in the porcelain or a wax ring issue before calling a plumber.
If it's indeed a wax ring issue, is it better off to keep using a wax ring vs replacing it with waxless? While the flange sits roughly flush with the finished floor, the floor is not entirely level (which I suspected could be what pulled the wax seal apart only after 4 short years).
Any help would be greatly appreciated. Thanks in advance.
