The regular pressure switch in the water pump has two springs, one for ON and one for the cutoff pressure. Our new pressure switch has only one spring. When I adjust it, the interval is always 20psi. It turns on at 10 psi, and turns off at 30psi or 20psi to 40psi. How do I make the interval longer when there's only one spring? When the pump turns on at 20, it only takes about 4 secs to reach 40psi then the pressure also drops very quickly back to 20psi even if only one faucet is open. I have searched and have not found any leaks in the system. Thanks for your help! Here is a link to a picture of the switch. (w/o the cover)
Thanks again!
Thanks again!
