I will add that if you use a slip joint long sweep at the bottom of the laundry sink, you will need a "trap adapter" to go from slip joint to solvent weld before the sanitary tee to merge with the standpipe.
Like this?do not forget your flanged tail piece or you will be making another trip to the hardware store
