goofy78270
I recently replaced my water heater, but when getting it inspected, I was told that I need to add an expansion tank. I also noticed that after sitting for a while, the cold inlet line tends to get warm due to the back pressure.
I have looked through the 2018 code, which my current jurisdiction used, but am unable to find an answer to my question.
With the addition of the expansion tank, can I also add a flow control valve to the cold inlet line to force all expansion into the tank rather than back fed into cold line as well? If so, should the control value go before or after the shutoff? Also, I have seen the expansion tank installed before and after the shutoff...does location really matter?
Side question, what are thoughts on an TXV, thermal control value, versus an expansion tank?
