Hello! My problem sucks. Recently had a bathroom flood and the toilet drain is the problem. I called a plumber out he confirmed the 90 degree elbow set directly under the flange was too high in my concrete slab. He replaced the elbow after jackhammering and reset it but I think its still too high and he said this must have been the end of the run when the house was built. The new elbow sticks up about 1-1/4” above the slab right now. We are replacing the flooring with luxury vinyl plank flooring so not much gain there. The elbow seems to not to curve until 2-3/4” inside the elbow female end so that would be where a flange would bottom.
Any suggestions on:
1) How much I could safely cut the elbow?
2) Trim the male side of the flange?
3) Are there toilets that have a recessed drain connection?
4) Is there a thicker toilet bowl floor spacer than what Oatey has in 1/8”?
Thank you for all suggestions
Any suggestions on:
