Hello Plumbing Gurus: I would like a dual 5-gallon water jug pump which will be able to lift water from jugs in my basement utility room to my kitchen sink and refrigerator (which are directly above the utility room.) I could build a shelf for the jugs higher on the utility room wall if necessary. Also, the pump could be mounted on the utility room wall or under sink. I am worried that the standard 5 gallon water jug pump systems are not strong enough to transport water 6+feet upward to a sink mounted drinking water spigot.
Please advise on the best possible setup! Thank you!
