3 Toilets in home. 2 upstairs are American Standard Cadet's. One on main floor is different model of an American Standard. All started to do the following...they flush normally and completely, never require a 2nd flush. The water fills the bowl normally. Then within a short time the water level in bowl drops 3/4 to 1"...and usually holds that level, sometimes overnight it might drop just a tad more but nothing major. I have plunged all 3, augered all 3, no blockage. All other drains in house work perfectly and drain normally. Suspected maybe a partial blockage in vent pipe (wouldn't be totally blocked would it if everything else works fine?). Called 2 plumbers (reputable in this area) and they wouldn't even come look, advised cleaning the roof vent first. Vent is 3". I called Roto Rooter and another local drain company (Drain Master) and both advised that they do not get on 2nd story roof's. I asked if this was because of winter, and they both said no, they don't even do it in the summer. So here I am . not even sure if it is a roof vent problem or something else (something else hopefully since no one will get on roof).
