I have a 3" cleanout plug outside that will no longer screw into the cleanout pipe. The cleanout pipe and plug are not PVC. Some sort of galvanized metal? My house was built in the 40's. In any case, I went to Lowes and bought a 3" PVC Cleanout Plug. When I got home, I tried to screw it on, but the threads in the pipe are messed up (broken off and corroded) and I can't get the plug to screw on! Do I have any other options to seal off this pipe? Could I use a PVC Test Plug Fitting (http://www.lowes.com/pd/Oatey-3-Dia-PVC-Test-Plug-Fitting/3880609)? I would like to avoid having to have a plumber come out!
