vestaviascott
I recently had to replace the tub faucet in our jack and jill bath. The plumbing in this bath has not been upgraded yet - hopefully we can budget for it soon but I need a temporary fix until then.
I've gotten a new 2.5" 3/4 galvanized pipe nipple to replace the old one and wrapped the threads with the gray teflon tape, about 6 turns. I then applied a good coat of T plus 2 pipe thread sealant over the tape and threaded the nipple into the rusty knuckle joint and tightened it up good. I let the connection set for 2 days before attempting a water leak test and in testing it today I have a slow leak at the nipple joint.
Any suggestions short of ripping the wall out and redoing the plumbing?
Should I try something other than galvanized into this 3/4 joint? Or try more pipe thread sealant, more/less tape, or what?
