guitarfish
Hi everyone,
I've been in my home for 20 years now, I have a well, and have had lots of plumbing problems. Water heaters last about 5 years. Around year 15 I started getting pinhole leaks, close 6-8 of them over the next 5 years. Finally last year I replaced all my copper with PEX.
My system goes like this:
1" water line to house - 1" PEX - check valve - brass tank tee - (pressure tank, gauge, etc) - 3/4" PEX - sediment filter - then to the house.
This week I discovered a pin hole leak in the brass tank tee. I'm guessing the tee is 10 years old.
I've never had my water tested, so I can have that done. People have suggested a water treatment system. But it seems like these are always placed after the pressure tank. So even if I had one, it wouldn't have helped the tank tee.
Thoughts? I usually have to replace the pressure tank every 8-9 years. I suppose I could be proactive and replace the tee and all the accessories at the same time and this might be enough to prevent trouble. I have a Manabloc and PEX home runs to all the fixtures. (There are shutoff valves at all the fixtures which are metal).
I was hoping after the PEX project that I'd have some peace for a while (years), but I only made it 8 months.
