I had a leaking T&P valve that caused quite a mess in my basement. I figured the 30-yr old valve was gunked with sediment, so I replaced it, but the new one also leaks.
I turned down the house supply pressure on the Watts pressure regulator. My pressure meter shows I'm at about 40psi (which makes filling the tub take forever). I also turned down the temperature on the heater so it comes out at about 125*F.
What else can I look into to solve the T&P leak? If it makes a difference, I have a 100gal gas water heater and the house was built in 1981.
