johndoe123123
I need advice on the best whole-house water conditioning/filtering system.
I have a house on a well with hard water, which necessitates the use of a water softener. I also get sediment from time to time from the well, that I need to filter out. I
would also like to improve the taste of the water, because currently I do not drink it, although it is perfectly safe to do so.
What is the best solution to my problems within a reasonable budget? I'd imagine some sort of whole house filtration system would be key, but who makes the better ones at a
reasonable price point? Or is a simple canister filter or similar from home depot adequate?
Finally, since the filtration systems are typically prior to the water softener, is it possible to reduce the sodium (salt) taste and count that is present in the water due to aggressive softening?
Finally, here is the water report if it helps:
https://docs.google.com/file/d/1n1J...HoolYJrZUctEIeW8DrU6zJ7w6jeO/edit?usp=sharing
