attached is a pic of basement floor of a triple decker. these are lines running under the basement floor.
we know this much is certain. there are frequent over flows of the bathroom line and we know that the cause can be found at the merge point of the bathroom line an the kitchen line before a single line exits the front of the building. there is too much going on at this point.
the sewage lines are cast iron and old, but the bathroom line is clear of any blockages and looks ok.
condition of kitchen line is unknown
the washer is not permitted, not vented and does not use a slop sink. the usage is really high for this washer. these over flows happen during months where there are many overnight periods with 12 straight hours of usage of this washer at 25 cu ft/hr.
what is the likely cause?
The Washer or
The bathroom line or
The kitchen line
the choices for solution are
remove washer and its high usage
cap the kitchen line from the stack to the washer and create a new kitchen line that meets the bathroom line in the front of the building
cap the bathroom line from the stack to the washer and create a new bathroom line that meets the kitchen line in the front of the building
The Washer or
The kitchen line
