Pabloguitar
My water softener and water filter each drain into my ejector pit in the basement which is finished. I'm concerned that one day my ejector pump will fail and it will happen at 2:00 am when the softener or filter are backflushing large amounts of water. Would it be Ok to route these backflush lines up and into a utility sink in the garage, thus eliminating the potential for a bad ejector pump from ruining the finished basement? It is not an option to run these to the regular sump pit with battery back-up due to the regular sump pit is at the other end of the basement.
Thank you!
Thank you!
