Frontier05
I was changing out the 3-gallon flushers in both bathrooms with new water saving commodes and saw a round offset flange in the guest bath. Double stacked wax seals were used previously. Wax is messy and it has to be installed just right. I was considering a Danco Perfect Seal which partially encapsulates the wax at the flange level leaving a generous rubber gasket to seal to the horn on the commode. Supposedly, the commode can be removed without damaging the wax seal. On the other commode, there was no offset and I installed a Fernco Wax-Less seal which is working well. Anyone have experience working with offsets? The house has a concrete slab floor. I've spoken to my plumber and he's willing to re-do the drain line and install a new flange for about $450 not including repairs to the floor. He concurred to try the Danco PS or another set of double wax rings. Any suggestions? Thanks.
