We have an under the slab leak more than likely from pipe freeze this Winter. I don't think the leak goes that far underneath the slab.
Is it possible to fix such leaks without having to use a jackhammer to go through the slab? Or does the slab actually cover the pipe up from when they originally poured the cement foundation?
Has anyone actually done some digging underneath a slab to fix a leak or is that even possible?
