watts premier hot water recirculation system installed, cold water stops flowing!
Benjamin S
Jan 6, 2025
watts premier hot water recirculation system installed, cold water stops flowing from back master bathroom cold faucet several times a day. Any clue what is the issue and how to fix it? TIA
I'm betting you do not have a dedicated return line for the circulating system and have a sensor valve like below that uses the cold-water supply line to the master bathroom as the return circulating line to the water heater.
I would guess either this valve or a check valve in the system has malfunctioned.
Pictures around the water heater, circulating pump, and under the master bathroom sink would help. Also, a sketch of the watts premier hot water recirculation system woud help.
