I installed a watt hot water recirculation pump last week and everything seemed to be working properly. Then I noticed I was getting warm water at the faucets that had the recirculation valve even when the pump was off. I unplugged the pump and I am still getting warm water at the faucets two days later. My house is on a slab and my pex lines run in the attic above the water heater. I dont know if this has anything to with my problem or maybe a possible water leak? I tested the resurculation valves and they are working properly and double checked all my connections. Any ideas? Thanks in advance.
