I need to connect a garden pond pump (submersed) that has a 3/4" male thread outlet to 1.5" tubing that's already buried in ground. Tubing runs up approx 2 feet to top of waterfall.
1) Is it even OK to attempt this? Pump instructions indicate that I SHOULD use 1.5" tubing, but it seems large compared to the 3/4" outlet on the pump. Trying to maximize the water flow I get out of this 1800 gallon per hour pump, but maybe I should be using smaller tubing. Does going from a smaller outlet to a larger tube violate some basic plumbing rule?
2) What fittings can I use to accomplish this? Goal is to connect the 3/4" outlet to the 1.5" tubing, but there's no simple 3/4" FPT x 1.5" barb connector. In fact I haven't seen any such connector with a larger barb than its FPT. I suppose the answer will be a combination of a few connectors, but I can't find all the right pieces.
I'm a novice - please help!
Thanks.
Thanks.
