Complete novice here and just installed a new toilet. Easier than I thought. However, now I attached the water supply line and I needed about 8 inches, but store only sells 9' and 12' lines.
Looked like they bend, so I bought the 9' and attached it with a bend. It looks like this:
I'm worried the pressure from the bend, over time, will put too much pressure either on the 1) water supply line or 2) tank itself and cause a horrible leak.
Should I be worried and try to find the perfect 8' water line? Or is this bending a standard procedure and the pressure isn't something to worry about?
Thanks for your time.
