I am studying water softener systems as I do not want my drinking water coming from a salt brine solution. There has to be another method.
Any comment on the following system- Pelican NaturSoft Salt Free Water Softener - PelicanWater.com
I found these two questions interesting in their FAQ-
Concerning Municipal Water-
Concerning Magnetic Water Softeners-
Isn't city water good enough without a Pelican Whole House Water System?
Most municipal water systems use chlorine or chloramines to treat water which are chemicals designed to kill living organisms. While they do an excellent job treating your water, they create dry skin and hair, unpleasant taste and odors that many people do not like. Pelican Water Systems filter out the unpleasant tastes and smells to provide clean filtered water, rich in mineral nutrients, from every faucet, shower, and toilet in your home.
MAGNETIC WATER SOFTENER / MAGNETIC WATER CONDITIONER (USES MAGNETS)
About Magnetic Water Softeners
The majority of these devices claim to work by causing the carbonate salts that would ordinarily form adherent scale deposits to precipitate as small particles within the water instead. This would also presumably reduce the concentration of the calcium and magnesium ions that react with soaps to form insoluble scum.
Advantages
Magnetic water softening claims to reduce the scale build up and the affects of hard water. The magnetic devises are very inexpensive compared to other methods of softening water.
Disadvantages
The degree of efficiency is constantly changing. The magnetic field exists only in the immediate vicinity of the device and therefore only affects behavior of water that has passed through the immediate vicinity of the device. The state of the water after it has been introduced to the magnetic field will only stay in that state for a period of 48 hours, which means if the water is not used for more than 48 hour it will revert back to hard water with the negative effects. The Tests conducted at Purdue University found " no significant, beneficial variation in the physical or chemical water quality parameters measured." Another disadvantage is that there is the possibility of experiencing interference from other high voltage cables in the surrounding area. Note: GMX magnetic systems were not tested by Purdue
