Plumbers, is it reasonable and customary to include a drain as part of water softener pre-plumbing? Does the description "water softener loop" mean ONLY the supply loop is included, or would you still install a drain?
Background:
Verbally, owner requested pre-plumbing for water softener. Plans show water softener in garage. Written specs include "water softener loop".
This area has terrible water. Most builders install a supply loop and standpipe drain. This plumber installed supply loop, but no drain. Builder said, "Usually people just drain it to the washing machine standpipe. Trouble is softener loop is in detached garage, laundry is in main house. Builder says "We can just go up and over the breezeway I don't think that is a good idea. Code official agrees.
Plumber said, "nobody said anything about a drain". Builder reluctant to remedy this problem at his cost, as drain wasn't in specs.
I know there are several possible remedys, and we can discuss that later, for now, I 'd like to stick to the question at the top of post, whether this is reasonable and customary. Thanks!
Background:
