Water Softener Backwash... are these setup ideas okay?
Jan 2, 2013
21
We had two "water specialists" come by yesterday because we wanted to hear what their plans were with regards to water softener setup and backwash. We already decided that we absolutely will not permit the backwash to be tied into our (very small) septic system. We will do the work ourselves (have enough experience). For clarity, I created this graphic to try and explain what they suggested:
We have a 1986 split entry home where our basement is only about halfway into the ground (the kind with the pony walls throughout). We live in Nova Scotia, where we do get freezing weather in the winter, but usually it hovers around 0 C most of the winter, sometimes dipping to -10 C, and very rarely more than -20 C. The frost line is usually about 3 ft below ground, but every so often (very rarely) we get a deep freeze where the frost line is like 5 feet down (happened a few years ago and some people had an issue with their septic tanks freezing).
The first guy wants to go from the tubing to 3/4" drainage pipe, and then have that come out our wall just above the concrete, and point down toward a 4" sewer pipe (they would not actually be connected, so there would be an air gap. Then the sewer pipe go a couple of feet below ground, turn to the right, and run paralell to the house, past it about 4' and to an underground gravel pit (dry well).
The second guy pretty much wants to do the same thing, only from the tubing to a 1 1/2" drainage pipe to a 3" pipe to catch the water and go under ground.
Something like this shouldn't freeze, right? Which way is better? First? Second? A combo of both? Neither?
Furthermore, we looked everything over today to make plans for plumbing, and thought that it would be a lot easier to make a longer run for the backwash throughout the heated envelope of the house, and then come out the side of the house to a 4" sewer pipe so we only have to dig a trench that's 4' long to go past the house (instead of a much longer trench outside; although I was reading 10' away from the foundation would be much better).
We want to run the drainage up along the ceiling, then go back down and out the far wall just above the concrete. As you can see, the upper half is wood covered with drywall, the lower half is concrete (covered with spray foam insulation):
So that leaves me with a few questions...
The total drainage run inside would be about 24' 10". From concrete floor to ceiling (bottom of the joists) is 7' 6" (though the softener drainage I don't think comes from floor level; we don't have the softener system yet).
On Inspectaepedia, it says this:
Water softener drain line routing: Keep the water softener drain piping as short and low as possible: less than 30 feet in length and no more than 8 feet above the floor level.
The drain line must be of adequate diameter to handle the water conditioner's backwash flow rate. Use a 3/4" diameter pipe if the drain flow is more than 7 gpm.
We are going to be getting a 2 cubic softener system (60K grains). I believe it says something about outputting 10 GPM. I assume that also means for backwash? Not sure. But isn't what comes out of the softener system a 5/8" tubing? At what point would we transition to at least a 3/4" drainage pipe? Would it be mainly 3/4" pipe we would put along the ceiling? The length and height of the drainage is sufficient in our case, right? We we need to have the long run along the ceiling on a slow grade downwards toward the wall?
The only difference I see is the pressure 5/8” connects to a gravity 3/4” or gravity 1-1/2”.
I would think 1-1/2” is better having less chance of ice causing a complete clog.
The rest sounds like you know what you are doing. I live in a 1’ frost line zone but it never freezes under 8” deep. No advice from me on the cold, except heat tracing, which is overkill I’m sure.
Not to sound rude, but you called two professionals out there to tell you how to do the system but said you have enough experience to do it yourself? I hope you paid them for their time, because it's a bit unsporting to call two professionals out to waste their time when in reality they have no chance of getting the job that they in good faith came out there thinking they could get because you're going to DIY it.
I agree with the two above. Not cool. Different story of you just want to do something yourself and come here to ask opinions of people freely wanting to help, but calling someone out to steal their time and expertise so you can save money is a real rat move.
Yeah, you do sound rude. We were fully willing to pay others to get the job done (hence calling them in), but it turns out they'll only do half the job. Might as well do it ourselves, save the $1,000, and use that toward doing the outside trenching and work properly for the backwash. Most "professionals" also want to tie the backwash into the septic system, which is a terrible idea, especially since we only have an 800 gallon tank.
So you had two professionals come by and explain how they would do it.
Nice.....
I’d do what they said they would do. 👍
One of the "professionals" wants to actually put the softener in a different place and cut through the header for our stairs to route the backwash. That's not even to code and weakens our stairs above. So no, I don't necessarily trust what they have to say, and will get more opinions on the matter.
Wow, this forum is nearly useless. Bunch of complaining, judgemental people that have no idea what our situation is.
I’d cut through the header too.
Well, Instead of being judgmental, we should focus on what is being asked and should try to give the solution if known...
The poster had two professionals come by to hear what they had to say.
What could you possibly know that two different professionals missed while standing in the home ?
But.....I’m all ears. I’m following the thread.
Personally I’m not even that arrogant to second guess two pros that’s been IN the home.
Even when the "pros" have contradicting "solutions"? Such as a third one that wants to punch through concrete and tie into my basement footing drain tile? And the one that wants to drill a hole through my stairs header? Bad idea.
I'm not stupid. Even "pros" make mistakes. Some "pros" recommend tying into the septic system. Um... no.
