finn
We received notice from the city that they're going to be doing work on the main line this Friday and as a result, all water service will be shut off for the day. We have a tankless water heater system (Rinnai) which has a close-off valve near the unit. Can we make do with just closing the valve for the duration of the work? Or do we need to turn off the electronic unit itself? We also have a water filtration system (Halo) - this system has a valve that allows supply water to enter and treated water to exit - the valve has a normal and bypass position. Is it ok to just set the valve to bypass while the work is taking place or do we need to turn off the electronic unit itself? The water company was not very helpful so any advice would be much appreciated!
