NorPlan
Active Member
As some may have gathered I'm in the process of getting the Backyard Pool up and running for another Season..This is the 1st home that came with an Above Ground Pool..So we have been tweaking the process each new year from how the previous owner had things setup..
At the Business end of things there is a 3 Way valve which enables one to Shut Off flow from Centre Drain,Skimmer,Pump/Filter..Past 2 seasons with Pump running and through the Filter and all the Pressure topped out at 10/11 lbs...Don't know why but the Previous Owner had a Guard preventing you from turning the valve handle all the way around, consequently when the valve was open to circulate between Drain,Skimmer,P/F...They had the valve open only 2/3rds of the way coming from the Skimmer...
This year I took the Guard off opening all avenues full..The Pressure Gauge shows on the + side of 15 lbs Now...Having said all this, What is the Average Operating Pressure the Pump should be showing when Vacuuming the Pool... Cheers. Thanks...
