I could do with ideas for addressing a water pressure spike problem. About 5 years ago, shortly after buying the house, I discovered the water pressure was ~80 psi, with occasional spikes to ~120; and we lacked a PRV. A plumber installed a PRV, set it at 40psi and installed an expansion tank on the electric water heater, also set to 40 psi. We've been dissatisfied with the low shower pressure for years (it's upstairs) so I finally decided to address it, but checked the water pressure as the first step. Static pressure is 40psi, but we were getting spikes up to 120psi during the evening/night. My first thought was thermal expansion due to a ruptured diaphragm on the expansion tank, but depressing the schrader valve on the tank only let out air. I then tested the pressure in the expansion tank, taking the following steps:
1. Shut off power to the water heater
2. Closed the cold water flow to the water heater
3. Opened a hot water faucet (ran dry very quickly)
4. Let some water out of the water heater to take pressure off the diaphragm in the expansion tank
5. Tested the air pressure in the expansion tank (~36psi)
6. Put the air in the expansion tank back to ~40 psi.
In short, the expansion tank seems fine.
That suggests the PRV is faulty, but we know the mains pressure was 80psi 5 years ago when we set the PRV to 40psi. It doesn't seem reasonable to think that in that time the mains pressure in the neighborhood has coincidentally been dropped to 40 psi, the PRV has failed and the 120 spikes we're getting are coming from the mains. That said, I can think of no other way we could be getting these spikes.
Lastly, my hunch is that it's related to the water heater because the spikes seem to be at night (that's when my wife and daughter drain the heater with showers and baths). Right now I'm trying to cause spikes by running the hot water for a while, shutting it off and watching the pressure gauge on an outside faucet. But, I've only seen small pressure changes.
Any thoughts would be much appreciated because I'm out of ideas.
I should also have said I'm writing from the US.
