Hi everyone,
We recently had a water softener installed and asked if we could have at least 2 of our 4 outside spigots bypassed so we would have normal water to water plants and flowers. Under our house which was built this year so everything is PEX and they tapped off the main water line before going up to our utility room where there is a pressure regulator that reduces the pressure for the rest of the house. He installed a small shut off valve inline on the new line going out to the hose bibs.
On a hunch I attached a PSI reader to the hose bib and the PSI reader only goes up to 200psi and it's maxed out at that. I called the water company to ask them why they didn't check that and they said they don't because it doesn't matter, the PEX are rated for 300psi and the bibs don't need to be regulated. This sounds like BS to me but figured I would check around before having a cow on the guy.
Thanks,
Mike
Thanks,
Mike
