Mick
Hello,
I am having a problem with reddish, flaky sediment in my water (could send picture), which slowly clogs everything from my sprinkler system, to my washer, to being present in my toilet bowl. I've called the city, who flushed the street, but otherwise said it wasn't the problem. I've also experimented with turning on all water outlets in the house to flush all conduits in my house, but the problem is only getting worse (although it seemed to have reduced significantly in the winter). I believe I've narrowed it down to my water line, running from the street to the my basement (approx. 25 ft). The water line appears to be galvanized steel, which I understand corrodes, and it is perhaps releasing years of mineral buildup. I was quoted $3000 to replace this water line, which is obviously not making me any happier, and the guy couldn't actually guarantee that the problem would go away! My questions are as follows:
1) do you agree and how can I be sure the problem is the water line?
2) Is replacing the water line my only option? What about installing a filter/strainer? Would this type of solution only buy me so much time, as the problem is likely to get much worse? I'm fine with having to go to the basement and clean the filter on a weekly or monthly basis if it saves me thousands and is viable for several years.
3) Any other suggestions?
Thanks in advance for any help
