Hello,
I removed a fiberglass shower to install tile, and shortly afterward, my water heater started leaking from the temperature/pressure relief valve. I have drained the water heater, replaced the TP relief valve, lowered the water temperature setting, and lowered the inlet water pressure, all to no avail (lowering the water pressure slowed the leak, but it's still present).
When I removed the shower head and mixing valve, I shut off the main water supply, and capped off the hot/cold water pipes by soldering caps onto the ends. Could the introduction of air into the shower pipes (from an upstairs bathroom) have caused a leak from the water heater TP relief valve (in the garage)? If this is plausible, would installing temporary valves that would allow me to bleed out any air from the shower water lines help?
Many, many thanks for any advice you can offer.
