bikeboy
I am having a water heating problem with my 50 gallon electric water heater. Tank is only a couple of years old. The water is chlorinated coming from the street. Living in Tennessee, The water line from street is only 18" below grade, and @ least 500 ft. before entering tank. With both thermostats set @ 120 deg. , I'll get 90deg. @tub spickit. when turned to max. reading 150 deg. @ tank, I'll get 110deg @ tub. This is after letting thermostats shut off heating elements, and set for a while . It's only a problem when i cant fill whirlpool tub, esp. in winter months. I tested the elements resistance, and continuity, voltage and amp draw. Elements seem to be good. Thermostats are set against tank. I've once cleaned the elements w/ clr to remove sediment. There is probably now some chlorine sediment around the anode rod and elements, but the thermostats are shutting off, @ given temps. The only thing I can come up w/ is the therms. aren't accurate. Also, when tub is filling, water has greenish tint. There is a notable difference, when ground water temperatures change, but shouldn't change heaters operation when resting.
What do I look for ?
HR...
HR...
