Hey guys,
Dont plenty of DIY plumbing at work & home for a while. I recently had to install a new water heater due to the old one failing February of '23, and I just recently started experiencing rust colored water from the hot side.
I flushed the water heater for an entire day (drain, flush with pressure, fill, repeat), and the water has cleared up but still has a brownish tint to it and is noticeable. I put a borescope into the tank and saw rust collecting on quite a few spots in the tank. I'm not well versed on what the expected look of a water heater is supposed to be inside, but I cant imagine rust buildup on a glass lined tank is normal (I have all PEX piping in my house and its built in 2010).
I've attached pics for reference. Tank is an AO Smith 50 gallon heat pump hybrid water heater. I also have a brand new water softener/carbon filter system feeding the whole house that I had installed when I bought the house in Sept '22.
Thanks in advance for the advice!
