ron16
My mom has a 7-8 year single element water heater. Water was only luke warm. Replaced the element twice (in case we got a bad one) and the thermostat (set it at 140 degrees). No change in water temp. Drained tank again to check for corrosion inside but appears to be fairly clean inside. So we have replaced every electrical piece on the water heater and still only have slightly warm water. Can someone shed some light on this? By the way, there is 240v at the element. So I know its not low power.
