ExtraDuty
I noticed that the TNP valve on my 13 year old GE Hybrid water heater was leaking (approximately a quart of water each day). I figured after 13 years, the Watts 100XL (150 psi 210 F degree) valve went bad so I went to Lowes and purchased a new Cash Acme 150 psi 210 degree F TNP Valve to replace it.
Today after morning showers, I noticed water leaking again so I started troubleshooting and here is what I found:
1. Water heater temperature is set at 115 degrees and the water temperature coming from any faucet on full hot does not seem to be above that.
2. I attached a pressure gauge to an outside hose bib, turned the water on and it went to 100psi.
I relieved the pressure from the hose bib, went inside and turned a faucet on, went back out to the hose bib and turned it on, water pressure then was 60 psi with water running in the house.
After turning the indoor faucet off, the pressure then read 80 psi and stayed at 80 psi for approximately 5 minutes before i disconnected the gauge.
Where do i go next?
~ Maybe a bad TNP valve from Lowes and replace it again?
~Has the main water pressure regulator on the incoming line gone bad? If so, How can i tell?
~Did the expansion tank go bad? If so, How can i tell?
Thanks
Where do i go next?
Thanks
