Roger Dowdy
Hi All. My first post. Hope I post correctly.
My daughter complained of her hot water heater pressure relief valve leaking and asked that I replace the valve for her. I checked her house water pressure with a gauge at 60 lbs. Opened a bathroom hot water faucet, attached a hose to the tank drain valve, shut off the cold water supply and drained a few gallons of water from the tank. Checked the water tank pressure at the drain at the bottom of the tank to ensure pressure was off the tank then measured the air in her expansion tank. It was 15 lbs. Since I was suspect of the expansion tank and it was about 7 or 8 years old I bought a new one and with the new tank on the tailgate of my truck aired it to 55 lbs pressure, installed it, turned on the tank supply, put everything back to normal and went home.
Checked with her about two weeks later and all was good...no leaks from the relief valve. Couple of days later she called and said the relief valve leaked again one night. I went to her house found house water pressure good and no leaking. I put a water pressure gauge on the drain port of the water heater ( gas turned on and the heater in it's normal operating state and it showed 60 lbs pressure. Left it on the heater and asked her to monitor. About a week later the gauge showed it had been as high as 100 lbs. Went to her house yesterday after about a week additional time and the gauge showed it has at some point been as high as 150 lbs. which is the trip point for the relief valve. Current tank pressure at that time was 60 lbs.
What the heck am I missing? I thought of a stuck thermostat but
they haven't noticed any excessive hot water temperature in the house. Why would tank pressure rise that much just "sometime". One note: the expansion tank yesterday still seemed to not be full of water ( just tapping on the tank, bottom sounds "thud thud" the top half "tink tink". ( forgive my amateur discription. Don't know what to do next. It still hasn't leaked from the relief valve in two or three weeks but the pressure has been up there at least once. One note: The expansion tank is a 2 gallon tank and her water heater is around 60 plus gallons ( if memory serves me). I guess that's too small but I went with what was on the tank originally because of concerns about how the expansion tank was supported.
Forgive the long epistle but I was trying to be complete with what I posted.
Thanks everyone.
RD
Thanks everyone.
RD
