Hi everyone, I've had some difficulty draining my water heater and I'm not too sure how to proceed.
About 6 months ago, my water heater (which I feel like is about 6 year old, I'd have to dig up the paperwork) started making popping noises, so I decided to flush it since it probably has sediment in it. First, I've grew up in this house, but I've owned it the last 10 years. The previous water heater was about 20 years old and sprung a leak one nigh which is why we bought the new one. I mention that because I never heard any popping noises from that one ever. So, I do all the steps (cut the electricity, turn off the incoming water at the tank, open a hot water faucet) and hook up the hose and it is just barely trickling out. After about an hour I'd guess a gallon might have come out. I do open the T&P and that gets things flowing good, I know that's not ideal, but it worked. Probably take another 20 minutes for it to seem to empty from what I recall. Some sandy sediment comes out in the process, probably 2-3 tablespoons worth (from what I remember).
Ok, fast forward to a couple of weeks ago and I hear the popping. Ok, I was planning on doing the draining every six months so I do the draining this morning. This time, I do the steps, hook up the hose and it's coming out, but again pretty slow. Not a trickle, but a weak steady stream. I started this at 8 am and it's been running at the same pace until 5 pm. A descent amount of sediment came out, but I'm at the point where I had to stop since my son has to take a shower for something.
So here's the odd thing. I have the hot water faucet open, which should let air in, I have the water cut off at the water heater, yet I still hear what sounds like pretty loud bubbling or trickling in the tank. When I turn the cold water valve on at the Water Heater (I was doing it occasionally to stir up the sediment), it makes a distinct sound of water rushing into the water heater so I feel pretty sure that the valve is cutting it off, but maybe the valve isn't closing all the way resulting in the water heater taking all day to drain? I guess the only way to verify that would be to cut the main water line off.
Oh, I also occasionally (later in the day) tried opening the T&P valve to see if that would get things flowing (my water heater is in a closet in my hallway, even though I had the hot water tap open it doesn't seem to help with the flow so I was wondering if there could be dips or something in the pipes that create a natural vacuum), but that didn't seem to have any significant impact on the rate of flow.
Or, could there be enough sediment build up at the bottom of the tank that it would take about 9 hours to drain a 40 gallon tank even though it's flowing slowly?
Sorry for the long post, I'm just a little confused as to why I can't seem to get a good drain, except for the first time I opened the T&P valve. Does it sound like the sediment has built up too much? I saw some videos on removing the heating element to track and clean out the bottom of the tank, but I'd have to first get the water heater drained which seems like a chore in itself. Time to call in a professional?
