Removed waterheater with house water on, waterheater inlet valve closed. With the outlet line removed from the water heater a small but steady stream of water continued until the main house valve was closed.
Trying to determine if water flowing thru waterheater outlet indicates a problem with one or more of the single handle valves in the house.
