Hello. Need some advice. Long story short, started smelling some foul odors and realized this! The drain is about 1 ft ABOVE the front load washing machine. It drains across to the right, not straight down.
Went to Home Depot today and picked up some couplings, PVC, a 90° elbow and a "U" piece of PVC. Wondering if I should just attach the 90° elbow to the U and add 18" of PVC OR add some PVC to lower the U and then add 18" of PVC.
Not sure what is best for this situation seeing as there is limited room and because of the height/direction the drain is running as well as the drain being ABOVE the washing machine.
Any advice would be greatly appreciated. Thank you.
