Washing machine backs up in kitchen sink
ted
Jun 11, 2016
5
I'm thinking I need to install a back flow valve or check valve to insure this stops, especially since I'm about to install 2nd floor bathtub and shower drain in washing machine drain line on first floor.
Kitchen sink drains fine, although it is not a lot of water like washer, so I am assuming issue is volume of water produced by washer.
Please help. Thanks
What you have is a partial blockage. Washing machine and kitchen sink should never share a branch. Have the drain professionally cleaned and you will not have any back up issues.
have tried that and it did not help and in any case I can't take chance with bathtub draining into that line
cant do much about washer and kitchen on same branch either
Am I understanding correctly, that you have a drain that will already not handle the volume from the two fixtures that are attached to it, and you plan to add two more fixtures to it?
just because you tried that does not mean you did it correctly,
grease in a sink line is like a tub of butter, you can stick a knife thru it
but when you pull back, the hole closes.
call A PRO
