Heisenberg
I own a single family home on public water and have lived here for two years. The cold water used to run fairly cold, but one day a week ago after using the shower we noticed that the cold taps were running lukewarm from every faucet. I experimented with shutting off the water heater intake pipe and the main intake line, and after fiddling around with it grumpily for a half hour or so it seemed to go away. Today the incident returned and I can't get rid of it.
I researched the problem and it seems like the issue is most likely a "cross connection" between the hot and cold water pipes. The most common place for such a cross connection to occur seems to be cartridges in single-lever faucets. This would have made sense to me, since not only do I have three single-lever sinks and two single-lever shower faucets (all Delta as far as I can tell), I also had some issues with one of the shower cartridges when I first moved in--it was installed backwards, so hot and cold water were switched. I fixed that myself months ago and had no issues afterward.
I figured that cartridge or another one had gone bad. So I turned off both hot and cold taps at all five faucets, showers (behind the faceplate) and sinks (under the sinks). If I'm understanding this correctly, stopping the water at these points would prevent it from "crossing over" and mixing at the cartridge. However, no such luck. I tried turning back on one sink at a time and testing it. Each sink still runs lukewarm water from the cold tap even with every other single-lever faucet in the house turned off.
My understanding is that the only other point the water could really be mixing is if hot water rises up the water heater intake pipe due to convection. So at this point I also turned off the intake pipe to the hot water heater. The hot water taps, as expected, all cease to work when this pipe is turned. Amazingly, though, the cold water taps continue to deliver warm water! I wouldn't have thought that possible!
I don't believe the pipes are actually crossed anywhere (e.g. cold water pipe to hot water tap) or anything like that. As I said, everything was functioning fine until recently, so I have to believe this is a recent failure somewhere in the system. Aside from flipping the cartridge in one of the shower faucets, which was months ago, no other plumbing changes have taken place in two years. We have been running the dishwasher more frequently after rarely using it the first year or so, but I wouldn't think that could be the issue.
What the heck is going on? Am I correct in ruling out the faucet cartridges as the culprit or is there something I'm missing there? Could water still be backflowing up the water heater intake pipe even while the pipe is shut off? Should I call the water utility? Call a plumber? Call the exorcist? Help!
