Over the years we had called several plumbers to come unclog drains at a rent house, and they unknowingly knocked out two separate cleanout holes, and then just put a half piece of PVC over each hole.
Here's a pic of both cleanout holes, going from house to septic tank:
Pic
This summer i decided to work on the clog issue myself, and thats when i saw what they had done. I was planning on cutting that entire section out, and replacing with shielded fernco connectors and pvc... but when i excavated the pipe all the way, i discovered that each cleanout hole was punched through in an area that had concrete poured around the pipe.
So i mean... is there even anything i can do?
Could i chip out the concrete around the pipe enough to make a smooth section for the fernco to slip on?
Could i just bust up all the concrete/pipe, dig it out and put new pvc back down? My only issue with doing that would be that the lower cleanout hole is cemented in right where it joins the septic tank, and im not sure if i would be opening up a can of worms to bust all of that concrete up.
Pic of upper cleanout hole, surrounded by concrete on bottom. House is on the right, the concrete and pipe pass under the foundation.
Pic of lower cleanout hole... the hole is almost clear of the concrete enough to cut clean through, but on the bottom there is concrete extending out to where the hole is. Septic tank is on the left where the concrete starts.
Any ideas of what i can feasibly do here on my own? I mean if it's some monumental task to bust up the concrete or something, maybe i should just put the pvc back over the holes like it was, and then just dig it out myself when it clogs up, now that i know what to do?
Thanks for any advice!
Pic
