Wall mounted toilet help
Jourdan
Mar 19, 2019
Wilton, ny
Hi all,
So I'm redoing a bathroom for a customer in their basement. Their 3" abs drain is a mess and not set to the correct heights. The original toilet in the basement seems to drain fine. I believe theyve never had an issue because it is a raised ranch and their plumbing upstairs has enough force to move waste to the city sewer. I only need to raise the plumbing another two inches where the toilet will be going and I did not see a reason to use a grinder pump for that short of a distance. I talked the customer into a wall mounted toilet, so my question now is do I need to use a closet carrier to mount the toilet? or would it be ok if I frame the wall in a way that I could stub 4 bolts through with a closet flange and mount the toilet that way? Also I've read that if you're going to mix abs and PVC in your drain system all connections where the two different pipes meet should be connected by a metal banded fernco fitting. Is this true?
