That set up, no you cannot vent like that. What is the top pipe supposed to be? Why is it sticking out of the wall?
i would have brought the vent pipe straight up, cut out the rock behind the mirror. then covered it with a mirror
are you going to have a mirror behind your vanity sink ? thats pretty typical.
why not buy a hole saw bit. instead of notching? weakens the stud, makes plumbers cringe when they see "the Butcher"
if we do that, the boss puts a boot up the a$$ and inspectors freak out
it is also, helpfull to hold your pipe up.
when you lay out the hole for a drain. mark each hole 1/4'' higher , when you put your pipe in, its falling correctly
..............View attachment 6829
