I have an old gas shut off valve that has a small leak coming from the back plate. I used soapy water and found that a bubble fills from the back plate when the valve is open. The valve is not leaking from the threads. This valve seems to have a spring assembly and a bolt that holds the back plate on. Can this valve be disassembled and seals replaced or is it toast?
