cheryltlr1979
Hi
ive recently moved into a new home and wanted a shower but being strapped for cash could not afford to have one fitted, so I took it upon myself to fit a mixer tap and shower as it was easier.
So I changed the tap, I used PTFE tape and tightened the bolts as best I could ( obviously not tight enough! but now the hot water pipe is leaking, so i used epoxy putty around the bolt to try and stop the leak but it is still leaking.
I now need help to try and remove the hardened putty and get someone to remove the bolt or tighten it better than I can? Can anyone please give me some advice on how to do this easily without having an expensive bill to get someone out to do this for me.
Thank you in advance.
