Hi,
I have no plumbing experience and a small problem - I have been hoping you could share your thoughts and let me know what you think is the best solution.
I have a garage/shed/whatever you want to call it, which has equipment inside, which relies on steady pressure of water to work properly (it dilutes chemicals and any sudden jumps/decreases in pressure affect the mix). Inside this small building, there is a toilet built from a fake/cardboard wall, where there is a water pipe.
I have connected the equipment with the main pipe using a plastic 15mm pipe, as shown on the attached diagram. Unfortunately, the pressure is not really steady (it varies a lot) and it is far from being strong.
I was wondering - what should I do?
(a) Is there some small automatic water pipe which I could install between the plastic 15mm pipes to increase and stabilise the pressure?
(b) maybe if I drilled a hole in the wall and re-route the plastic pipe (to go directly from the toilet to the equipment) this would make a big difference to the pressure and its steadiness?
(c) ... or maybe there is something else?
Thank you very much for your kind help and time. I really appreciate it.
Best regards,
Dante
Best regards,
Dante
