Under sink help for a novice
Ajleibow
Jul 24, 2016
Hi. We moved into a new house. Double sinks in the kitchen. There is a little bit of a smell, and one of the sinks makes a bit of a gargling sounder when water drains in the other sink.
Both traps are not clogged. However I noticed that where the pipe from the sink goes into the pipe coming out of the floor, they arent directly lined up. So there is some space in the connection. See the arrow in my picture. One side I put some silicone to seal it. Is this the right thing to do?
Can you take a photo(s) of the entire install?
Attached. I think under the floor tiles the pipe splits with one side going to one sink and the other to the other, if that helps.
Thank you
They need to look more like this:
zanne/ kulutz
this guy is from over seas, he does not use the same plumbing we use.
but hey, Ajleibow, we have our own resident plumber from Italy
hang in there, do not get discouraged, I will contact him, depending on the difference in time, i do not know when he will respond
with in 24 hours for sure
Ahh! I didn't realize that. Sorry about that.
I wonder if that piece sticking up diagonally is to attach a "glu glu stop" aka AAV.
Alefromitaly has been extremely busy with work, so I don't know when he will be able to respond.
